Chris Hetrick
After I got the spark plugs fixed, I said I was going on to the gauges and lights in the dash. The proofreader seemed like an easy place to start, so I did. When I undid the cable at the back of the generator, it came off as in picture...the cable off the piece I am holding with the pliers off the gear drive unit. Should that piece I'm holding with pliers be attached to cable and not a separate piece? While I had it apart, I decided to remove unit and clean it, grease it and put it back together. The very first thing I did was remove the generator LONG bolt (well, it was right next to the one that needed taken off!) Didn't realize it till I had it out and it was much longer, I felt a nightmare coming on. Now I can't get that long bolt to screw back in to generator....any ideas?
