Ford Loader hydraulic actuator rebuild kit?
CCINGI
New User
I believe I have a Ford 19-105 front end loader on my 850 tractor (can't see all of the model number). I am trying to find the part number(s) for a rebuild kit. Can anyone point me in the right direction? I appreciate any help. Thanks.
19-105 doesn't return anything in the parts site. Where did you find the 19-105 number?
And what exactly do you want to rebuild? Your thread title says "actuator rebuild kit". Are you referring to the control valve, lift cylinder or bucket cylinder when you say "actuator? In any case, your best bet s to take the part that needs to be rebuilt off of the tractor and take it to a local hydraulics shop. They can match and find parts for most any control valve or cylinder.
The 19-105 is a loader within the 703-Series of loaders. I would first try Ebay and search for Ford 703 loader. Seal kits are available there, pay attention to all of the dimensions to make sure it's what you need. The parts diagrams and some parts are available online at Messicks, see link. Baum hydraulics has kits for the 703 Series but kind of hard to find online, may have to call. Lastly you should be able to match up all the packing and seals at your local hydraulic shop or seal distributor if neccesary.
703 Diagrams Messicks
The manual for your loader is on the other 'Ntractor' website in the manuals section.
It will list some specs.
Your 19-105 is the same as a 19-97 loader except the 105 has single acting lift cylinders, the 97 has double-acting cylinders.
good loaders...tough...but heavy.
