Ford 8160 Wiring issue
wireissue
New User
I own a 8160 Ford Tractor that started to give me fits this spring. I lost the use of my gauges, fan, and radio ect.... now it will run- Hydraulics work and my dash will work if I turn my light switch on, but will cancel out if I push my additional lights on. NOW it will not engage into forward or reverse. The code is F37 and F47 stating that the clutch switch is out for agustment or not found.
Ive been tearing apart wiring and have yet to find a problem Any Ideas???
Your manual should outline the procedure for using the on board micro-processor to run individual tests of the clutch pacs in the transmission. This will probably tell you that you have a bad seal in one of the clutch packs. What transmission does it have? How many hours?
Don't know about the 8160, but the service manual for the Genesis tractor (70 series) contains flow charts for trouble shooting the fault codes. That'd be where I'd start. Likely an electrical issue.
