Chris Hetrick
OK I know if it's not broke don't fix it...but, the plugs & wires were painted, cracked, oily, etc; so changed the plugs and ordered new wires. I changed the plugs and used the tractor several times before the new plug wires came today. It has been running & starting great...but now, I went to start it afterwards, and nothing. No crank, no click, nothing and my battery is charged, lights work, etc; Did I accidentally unhook a wire or do you have ideas? They were hard to change as there was little room and at one point I loosened the cap on the distributor to be able to get a wire on. I don't think I did anything to it and I put it back the way it was. There is just nothing when I go to start it... HELP! Maybe the switch that runs the neutral/start, is it located anywhere around there? But there's not even a tick just nothing when you turn the key.
