Mounting 502 mower need small pto shaft
Pslocum
New User
Need a small PTO shaft to fit a 860 Tractor mounting a 502 mower and the pulley fits a small shaft or maybe someone might have a pulley that will fit the large shaft? Thanks for your assistance Phil
I don't understand your pulley/shaft arrangement, but anyway you can get tubing couplers U-joits etc for most any sized PTO shaft in the PTO shaft display at virtually any tractor and equipment dealer. Even TSC has it.
The 860 should use the standard 1-3/8 shaft so are you saying the PTO shaft you have fits the old 1-1/8 shaft?? If that is what your saying you can replace the U-joint yoke with a new standard one and be done with it
