NAA position control
petehall
A friend has a NAA tractor that Position control down,The drawbar drops all the way down
But with the lever up,it will not drop all the way down???
Ive Archives this problem but no help
Thanks for any clues !!!!!
(quoted from post at 12:01:50 06/29/17) A friend has a NAA tractor that Position control down,The drawbar drops all the way down
ith touch control all the way down, moving from Position control mode to Draft mode should result in the lift dropping by approximately 3 inches. If more than that, then internal adjustments are in order.
