960 clutch p problem
pinball
went to start my 960 I hadn't ran on two years. finally got it running but I know it has a carb problem but I noticed when I push my clutch down it tries to grind some when I engange the pto if I leave the rpm up. if I take it down to almost idle it goes in okay but doesn't grind but just a ittle so is there an adjustment for that or is it a bad clutch. thanks for reading
Sitting for 2 years there is a good chance the flywheel and pressure plat have some rust built up on them and good chance by using it the problem will clear up on it own. As for an adjustment yes there is one and is in the I-T manual as how to do it
Adjust free play, next put a load on the pro an start traveling, and go to half clutch then full clutch and see what she does, post back.
