Waiting for new brake cross shaft and seals to arrive did a little searching and ran across this thread.
http://forums.yesterdaystractors.com/viewtopic.php?t=593696&highlight=seal
In it, 2nd post from bottom, Hobo,NC says to install the Right seal after the cross shaft is installed? I do not plan on making or buying seal installation tools, a correct size socket normally works pretty good. However using a socket won't work if I need to install the seal after the shaft is in.
Guess my question is whats the actual problem with installing the shaft with both seals in place?
