Nc Ford5600
New User
Greetings,
I have a ford 5600 and it was running great and then starting ideleling strangely then would die. I filled the tank with fresh diesel bc I thought maybe I was empty. After that I would get it started but it would only run for about 5-10 min then die and I would have to use starting fluid to get it back going and it would only last for the same time. Now it will not stay running at all. It has a new battery and so I feel it is not getting diesal. Figure it's the pump or a clogged injector about to start messing with it, I would love any informtation on trouble shooting the issue as I have never had the mess with this part of the tractor much other then change the fuel filter. As of now there is gas in the tank and fuel going to the filter as I unscrewed it. Thank you -Tim
