Wanting to find out if anyone knows how to test to see if the sending unit in the tank is actually "working". Also, anyway to test if the fuel gauge in the dash is working? I do know the fuel gauge and the temp gauge on the dash do not work, but the back light on the cluster for the fuel and temp does work.
Another question. The tach does not seem to work properly. The needle is broke and if you are running the tractor at a certain position with the throttle, the round circle in the middle of the tach in which the needle should be on will start rotating all the way around. Any clues on how to fix any of these items and or test them? Especially the fuel issue. Like to know how much fuel is left and would be nice to know the temp as well. Tach I can deal with if need be.
Thanks,
Justin
Thanks,
Justin
