willneedsatractor
New User
Got a 1971 Ford 4400. Running a little hot dont trust gauges But after a long run the radiator gurggles and overflows. thought I would flush and change fluid and thermostat so opened up the thermostat and it wasnt there. gonna get one today but lastnight I thought i woulda go aheead and flush and then replace the thermo today. When i cranked up the lower hose collapsed and does it every time. before I put the flush in i could run water through the block and the radiator and when i drained the old antifreeze it looked fine. I am nervous of a bigger problem but everything seems fine. is this just because no thermostat is installed? should i get cap, hoses and themostat. oh and btw when i ran flush for 15-20min I stayed around 180. belt is tight but will whine at high rpms is that related?
