Hydraulic inlet tube elbow?
BobReeves
Anyone know how the inlet tube elbow in the rear end that holds the tube from the pump is held into the case. Parts only shows an O-ring. I thought it might just be a slip fit like the tube but it doesn't seem to want to pop out of the rear end.
Hoping it isn't held in with a clip or something on the inside that can only be removed through the top cover.
It screws in.
Exactly what I needed to know, thanks.
Might as well be held in by something under the cover, you can't unscrew it without first removing the brake and clutch cross shafts. That O-Ring can wait until I have to rebuild the cover.
