OK, how hard is it to get everything back together. I understand about using long bolts as guide pins and the importance of having both halves lined up in both plains but what about the clutch and PTO shafts.
The PTO shaft can be turned to align it with the disk from the PTO with it engaged but don't see any way to be able to turn the transmission shaft.
Also when you are dealing with two halves that weigh over 1000 pounds how can you tell if everything is going together as it should.
About a day away from being ready to put my 3600 back together and any tips will be appreciated.
