Leak between transmission and rearend 1973 Ford 2000
sweep
I have a leak between the transmission and rear end of my 1973 Ford 2000.
Is it just the gasket that needs replaced mating the two halves or is there an internal seal that goes around a shaft that also needs replaced?
Thanks for your help
Yes just a gasket,auctally its steel shim with raised rib in center. I would split, clean up surfaces and bead of perma-tex usuing original gskt and buckle it back up.
