Andy in Manteca
I'm at my wits-end. I have a 851 Power Master that is my working tractor, mainly mowing a ten acre pasture. The tractor was acting like the carb was fouled so I rebuilt it, keep stumbling every 5 mins of run time. I replaced the carb with a new
one - same issue, stumbles to the poling of shutting off the engine. I noticed rust in the tank and foul fuel in the filter - replaced the fuel lines, fuel shut off and cleaned the tanked, now the fuel runs clean, still stumbles after five mins of run
time but stays running but will continue to stumble every 5 mins. Perfect excuse for Pertronix ignition system (I converted to 12 v system last year with an alternator). After all this, still stumbles after 5 mins of run time. The symptom feels like
its running out of fuel with some backfiring. At one point I touched the coil and noticed that it is very hot - too hot to touch. The coil has the resistor inside. I'm at a total loss. Any ideas?
