Ford synchro transmission identify?
We bought a box of transmission parts that were marked 6600 Ford but obviously are not. Synchro style transmission.
Outer sliding collar is stamped 1240304272 and inner blocker ring is stamped 1250312087. Looks like most of the parts have a "ZF" symbol on them. Does this stuff look familiar to anybody? Maybe a newer model? Maybe not even Ford? Just trying to put the stuff in inventory.
Not sure about the ZF part but my 6610 has the 8x4 syncho trans with dual power.
Ford sourced components for different companies, it's possible ZF supplied parts or complete transmissions for some models.
The 8x8 and 16x8 transmissions used in 3930, 4630 and 5030's was made by Kubota.
Don't know of a way to convert ZF part numbers to Ford numbers.
The 10 series, from my understanding... used Clark syncro's. There was a change to ZF, I believe for the 12x12 in the 40 series. As you note,
the 30 series are Kubota.
I have no idea what the 3 cylinder 10 series used but I'd wager it was a smaller version of the 4 cylinder 10 series.
Rod
