Wheel center for 8160
RBnSC
Brother bought this from local airport. Only has 2147 hrs. It only pulled a big mower so they cut the lift arms off. Apparently they kept on running it with the wheel loose. Does anyone have center or some lift arms that would fit?
Ron
I think you'll find that center is NLA (new). I know a guy that had to buy the later style rim and center because that 8 hole center ( equal spaced) couldn't be had.
Later style is square with 8 holes paired.
I would also think they might as well get a rim too if they can. Those loops will be worn and keeping hardware tight will be impossible.
