riveroadrat
This message is a reply to an archived post by soundguy on January 04, 2010 at 12:13:43.
The original subject was "Re: 64 4 cyl 4000 gasoline fuel economy question".
Just my 2cents. I used to bushhog with my fathers 800 tractors and noticed that the gas engine wanted to bog at lower RPM than the diesel. I believe it is due to the very heavy flywheel on the diesel versus the lighter flywheel on the gas. A heavy flywheels turning torque is not easy to choke down. I wonder if you could put a diesel flywheel on a gas engine, bolts might not line up though.
