I have a Ford 5030. I think it is a 1994 or 1995. The serial number is BD72638, Model DU41WX. It is a two wheel drive, diesel. My wife was bush-hogging and backed into a stump and locked up the PTO. I have a new bush-hog, but the PTO is running way too slow. I assume we burned up the clutches. Also, the seal around the PTO shaft has been leaking (slowly) for a while. Can someone answer the following questions:
1. Can the PTO shaft seal be replaced without fear of having to break the tractor in half?
2. Does the PTO and rear differential use a separate hydraulic system from the transmission? Different fill points?
3. I have been told the PTO can be removed without splitting the tractor in half, by removing the seat and taking the top off the differential. True? If so, assuming I'm mechanically inclined, is replacing the PTO clutches something a mediocre mechanic can do?
