Well I've got the tractor completed and have done some bush hogging everything works great. The power steering works great but it is pouring fluid from the weep hole the cylinder has been rebuilt but I'm guessing the control valve spool must be worn out.
So I'm wondering what are you guys doing when the cylinder on the front is no good you can't get nothing but a rebuild kit orings you can't get the cylinder or the spool valve are you replacing with some type of aftermarket power steering if so I'm guessing you leave the front cylinder on there I'm just curious to what my options are. I thought about trying to make a spool valve I think the tolerance is like one and a half thousand. Thanks for any and all input
