Looking for Clutch alignment tool
BobReeves
Anyone have the clutch alignment tool that comes with the clutch kit you might want to sell or trade? For the Dual clutch in a 3600 or 3000.
I have a spare clutch disk and pressure plate I am going to take to a local re-builder rather than buy a complete kit. When I change it out I will need some sort of alignment tool.
It takes a little while, but I have made mine in the past from a wooden broom handle when that was the only reasonable option. You have all
the dimensions, just file or grind to meet them. Or if a hardware store is handy, get a dowel rod the largest diameter you need and cut her
down for the other two. It doesn't have to be perfectly round.
Ask you clutch rebuilder if they have the alignment tool.
My local rebuilder has a wall full of those plastic alignment tools, they normally send a alignment tool with the clutch.
I have two of them Bob, count the splines and let me know how many it has. If it is the same as the 4000, I can help you.
Sorry, saw your post but then forgot to go check the clutch. Not questioning your question just wondering... Is it possible for the 3000 and 3600 to have different splines on the clutch? I was under the impression they were the same.
After it gets daylight I will go out and count the splines in the spare I have.
