mike the pop
New User
Just got this NAA and in going over things I notice the previous owner had the position/draft lever wired to hold it midway between draft and position. Why?? I don't know. Anyway I removed the wire and put the lever into vertical for position. Then used it to lift and move my travel trailer with tongue weight of 600 to 700 pounds. It worked great, but I only had to lift a few inches. Later I put the boom on it to lift some other things,, less than 200 pounds and I find that with the control lever all they way up to the top of the quadrant, the lift arms only go up about half way. If I put it in draft position it does go to full height,, and then of course goes back down. I just did that as a test to see what would happen. I'm looking for some ideas as what to look for when I remove the cover. The manual doesn't really have a diagnoses for this type of issue. I'm hearing a lot about some sort of pin and/or a ramp or cam in there that could be worn.Thanks
