5600 Ford hyd. remote valve question
mark-east-tn
New User
Ive got a 5600 ford the hyd. pressure is 2500-2600 psi, the problem we are having is remote valve is leaking off when we close baler door it has plenty of pressure to close and lock but it leaks off pressure . I removed spool valve and took apart but really haven't found the problem yet. where could valve leak off pressure and how do I check it , looks like it machined to a tight tolerance ????
It may possibly be the cylinder on the baler that is leaking off.
One sure fire way to check is to close it securely and unhook the hyd hoses at the tractor. If the ends are good and (don't leak) and the gate comes loose then it is the gate cylinder.
Good Luck
Jim
