Last year I had to rebuild the 201 in my 555A due to a porous cylinder. The machine shop sleeved all three cylinders and decked the top of the block as he has found that a lot of BSD blocks aren't flat. I bought the machine used and it only shows 1900 hours, but based on its condition I believe that may be correct. Replaced the rods and mains but didn't grind the crank. It had headland pistons, but I replaced them with standard pistons for fear of the headlands coming apart. When I checked the piston protrusion I found it was right at the top of the spec. due to the decking. I also had the injectors checked and cleaned. It starts and runs great, but has an occasional metallic ping especially when under load. Maybe it isn't a big deal, but now that I know it is there I'm sensitive to it. Would the higher compression ratio from the decking cause the ping? Should I try backing off on the timing a little? If it was a gas engine these would be an easy "yes" but I'm not sure if the effects are the same on a diesel.
