600 generator
RDobbs
My 600 has a 6 volt generator that has started rattling
and knocking a bit. Could it be a bearing of sort or maybe
something else. Any suggestions appreciated.
Take it off and head to town to your trusty, local starter/alternator shop guy. It is there where he has all the right test equipment to check it out properly, under load, and tell you what's wrong. Then a simple rebuild would fix it, and no need to do a 12-volt convulsion. That's my advice/opinion, but, if you do choose to do a 12-volt flip, I'd be interested in your old original 6-volt generator.
[i:654c4848f0][b:654c4848f0]<font size="4">Tim *PloughNman* Daley(MI)</font>[/b:654c4848f0][/i:654c4848f0]<table width="100" border="1" cellpadding="0" cellspacing="0" bordercolor="#000000"><tr><td height="25" colspan="2" bgcolor="#CC0000">
<font color="#FFFFFF" size="3">*9N653I* & *8NI55I3*</font>​
</td></tr><tr><td>
</td><td>
</td></tr></table>
A loose bearing will cause the armature to rub against the pole shoes. It will ruin the armature in short order.
Just thought I would give update. Took generator off
and the big nut holding the pulley was loose. Still
interested in another 6 volt generator though as this
one is original and I have been into it since I've
owned it 30 yrs now.
