How do I plumb loader controls?Ford 6640
Wrh117
New User
Hello all, I have a 6640 with a loader that runs off the rear remotes. It's not handy when I need the remotes lol. Does anyone know what I would need to install a joystick control with possibly a 3rd function. Thanks
you will need a closed center load sensing valve, either two or three spool. You will need to tee into your remote valve's pressure supply line,
provide a place for the return oil to get back to the rear axle, and connect the valve's signal line to the tractor's signal line circuit with a shuttle
check valve.
