Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 801 Parts Online
Ford 801 / 871 Fluid leak
jmiller55
05-19-2017 20:03:47
Suspected O-Rings on Hydraulic manifold. Was incorrect. There appears to be a hole where there is not supposed to be one. Can anyone shed any light on this. Hydro Fluid exits pretty quickly when running. Hole is circled in photo.
showcrop
05-20-2017 15:38:56
 Re: Ford 801 / 871 Fluid leak in reply to jmiller55, 05-19-2017 20:03:47
Shaun, I looked at my 961 and my 971, they are the same. flush with the trans. So far as O-rings, read the OP and look at the pic.
Shaun Wallace
05-20-2017 15:22:36
That gap is there on all S-O-S, its not on 4 speed. The reason for 2 different manifolds is difference between XX0 and XX1 adapter plate. Them orings do go from time to time
showcrop
05-20-2017 10:37:09
I had to go out and look at a couple of my tractors in order to see how they look. The bottom of your manifold looks different from the two that I have. The bottom edge of the flange should come right down flush with the bottom of the trans. It looks like whoever you bought it from needed a replacement and got one which is different. Looking in the CNH parts page it shows two different manifolds.
WayneIA
05-20-2017 05:53:18
Is the photo upside down? I'm not smart enough to turn it around. Looks like part of the transmission case is broken out. And what is the red thing?
Larry NCKS
05-20-2017 05:02:13
Sorry, but that photo may as well not have uploaded as far as I'm concerned. It does not look like anything I recognize as part of an 801.
Sean in PA
05-20-2017 04:09:27
What does it loo like when the manifold is removed?
jmiller55
05-19-2017 20:29:37
jmiller55
05-19-2017 20:05:06
Can't upload photo... WTH?
