dobaroy
The clutch on our 3600 diesel engages right up top on the pedal and is real fierce (just cannot take off smooth) almost lifts the front wheels off the ground! How do we go about adjusting it, any help would be appreciated. Thank you
The only external adjustment on a 3600 is pedal freeplay. We generally set that at about 1 1/2 inchs or so. Does the PTO clutch work as it should? If not you may need a clutch.
Thanks for the reply and the clutch is not that old, only been in there for approx. one year. The pto clutch works real good. Will check the free play in the morning and try to adjust to about inch and a half.
