KYCASE1
How do you change the pto from 540 to 1000 rpm on a 7600 ford? I have never done this on a Ford. Thanks for the help. (This tractor does have the duel speed pto)
Park tractor with the front end 4" or more lower than back to lessen oil loss remove circlip and pull shaft from housing and make sure lube hole in side of new shaft is open do not operate tractor with shaft removed.
Do you have the 1000 stub shaft to use in place of the 540 stub shaft.
If so remove the cir-clip around the pto shaft, pull the 540 shaft out and install the 1000 shaft, then replace the cir-clip.
If you can have the front of the tractor headed down hill you'll loose less oil.
