michiganfruit
New User
I have a '53 NAA that starts, idles ok for 30 seconds then begins to run ragged.
I have changed the points, condensor, distributor cap and rotor, spark plugs, coil, ignition switch, and some wires. The spark at the plugs is occasionally (rarely) strong, and then it gets weak, sometimes there is no spark at all.
It is the original 6 volt system, positive ground system. I have done most of the testing with a charger connected to the battery... it doesn't help.
Any thoughts??
Any thoughts??
