Neutral safety switch harness install
Fallhunt42
New User
Hi, I ordered a neutral safely switch and harness and shifter assembly from yesterday's tractor.
Shifter assembly went in fine.
Harness for safety switch was very difficult to get rubber grommet through shifter cover plate. I tried heating it up with a lighter and warm water but ended up damaging it. The plastic seems to hard to compress through the hole.
Any suggestions would be appreciated. I am at a loss as to what to do next. I don't want to order another one and have same thing happen. Only thing I can think of is making one and getting a grommet to fit and putting silicone on it to seal it up. I would rather do it the right way and install the correct harness just doesn't seem to fit.
Thanks in advance for any advice
I did try Wd40 and when I tried pulling it I damaged harness.
I will order another harness and try the silicone
