Ford 961 Lift
David G
I am going to end up changing the bushings out in the lift, any magic on them, should I also change seals on piston while off?
Flip the rock shaft end for end when you change the bushings so that it will wear on the opposite side.
Dean
Yes. Always replace the O-ring and back up washer when the lift cover is off.
Of course you will also want to replace the cam follower pin and readjust the draft and position control adjustments.
I also thoroughly clean the sump and replace the oil.
Dean
I will post more once it is apart.
I talked to owner, will get shop manual for it.
Much appreciated
