Red Tiger industrial fuel pump
Fordfarmer
I've got the 2000 with the industrial repower pretty much done, except for straightening a fender and some cleaning. I'd like to take the fuel pump off and put a plate over the opening. Seems like I read that those plates are available...somewhere. Anybody here know? Or have one you'd sell (or swap for the fuel pump)?
Finding a block off plate for a Windsor or FE is easy, but I haven't found one for a Red Tiger yet. I think I have a pump from a 351 in the garage...I'm going to check if they might possibly have the same mounting hole pattern.
A ford 223 is a six cylinder version of this motor. With that being said Fel-Pro 6579 fuel pump gasket fits this motor and 99% of all motors. Soo a S/B ford block-off plate should work.
Well, I finally ordered a block off plate for a Windsor small block from my local CarQuest. Yep, it fits just fine. The one I got was a Mr. Gasket #1516.
