bbenefield
New User
I have a Ford 841 that the lift stopped working on. I want to give an explanation on what I've done so far (I have an I & T manual on this tractor).
I have pulled out the plug on the pump and made sure the pump works and it does. I have pulled the upper part of the lift off of the tractor to check the linkage adjustment and it is bad out of adjustment, problem is there isn't any more adjustment left. It also looks as if someone has been inside this tractor before and made an adjustment. I read somewhere about checking to see if there is fluid getting up to the plug that is on the top of the upper part of the lift, so I put the top back on to check this and I'm not getting fluid there.
My question is, other than knowing the linkage is out of adjustment, where do I go from here?
