Lift? Draft lever works only?
NAA lift works when i push draft lever down. Pops right up and works. But the will not fully lift otherwise.... any thoughts on this issue?
(quoted from post at 12:07:33 04/26/17) NAA lift works when i push draft lever down. Pops right up and works. But the will not fully lift otherwise.... any thoughts on this issue?
hat is because linkage is worn/bent/out of adjustment and pushing that lever down momentarily adds an additional force to move the control valve into the lift position.
(quoted from post at 08:12:44 04/27/17) cam follower pin is worn. search the archives you'll find lots of discussion about this
f that were his only problem, it would still lift in Draft mode. As I read his post, it will lift only while he is holding force against the Draft/Position lever,toward the draft position. If that is not what he is saying, he needs to clarify.
Jmor,
That's the way I read his post to. And generally if you move the quadrant lever to the top of travel and nothing happens, until you push down on the draft lever then the pin is worn. Pushing down on the lever makes up for the wear. Either way the lift has to come off and I'm sure there's more than one thing worn out.
Thanks, i appreciate the input... if may ask you about the top link spring...could that be a possible solution... i would like to try everything else prior to taking the risk for me of opening
it up. i do appreciate your time !
(quoted from post at 15:32:40 04/28/17) Thanks, i appreciate the input... if may ask you about the top link spring...could that be a possible solution... i would like to try everything else prior to taking the risk for me of opening
an you twist/rotate the big spring with your hand when top link disconnected? If yes, then with mode set to draft & touch control all the way up, tractor running, push on top link attachment point as hard as you can and note any lift movement.
