85burbanator
Replaced the starter so I could move some dirt and noticed before hand that the clutch wasn't always releasing. It would work but not 100 percent. Moved some dirt and it got progressively worse. Had to move and old truck up to the road to sell so I needed the tractor, it shifted fine into first and reverse, even into 4th and 5th to see if it would travel in that gear and it does. When I stopped to shift back into 1st, it tried over running the brakes before I forced it into neutral. The clutch wasn't working so I massaged it into first to park it by the garage. That's when I noticed it leaking white milk from the weep hole in the bottom of the trans housing. I have probably 10 hours on it and its been covered when not in use, the clutch thing just started so I'm hoping its ok.
The guy I bought the tractor off of never maintained it. Choke cable seized, grab some wire. Fuel pump stops working, bypass it. Generator quits, just charge the battery when you need it. Exhaust rusts out, jam a pipe in the manifold and try to weld it. Frustratingly easy things that I did as time allowed. The gear shifter spins so I pulled the cover to work on it, no gasket, just sealant that pealed right off. Found the source of the water. Going to order the parts to repair that.
Now, my question. I know Ill have to split it from the motor. I looked on Messicks parts diagram and saw no mention of a seal but have read of one in my online searchings. Is it a tight sealed bearing? What should i look for? I'm sure it will be obvious once I'm in there. Also, what fluid should i put back in? My manual jumps all over and doesn't list my transmission. I'm thinking a model specific manual will get ordered.
