Ford 860 lift control adjustment procedure
jvillads
New User
Hello, I have a Ford 860 that I have replaced the piston o-ring, backing ring and unloading valve o-ring, re-assembly is complete and requires adjustment. I have the Ford Manual but it requires special tools to complete the adjustment procedure. Wondering if anyone can post or provide a adjustment procedure that doesn't require special tools?
Thanks in advance
Follow the "alternative procedures" (special tools not needed) in the I & T FO-20 manual precisely.
If you run out of threads on the turnbuckle, replace the draft control fork.
Dean
(quoted from post at 18:04:04 04/23/17) Follow the "alternative procedures" (special tools not needed) in the I & T FO-20 manual precisely.
Dean
Thanks Dean, I am hoping someone would be willing to share the procedure with me as I do not have the FO-20 manual. There is not one available locally and to have one shipped to me is extremely cost prohibitive. If it is not possible for someone to share the procedure with me I suppose I will have to get one but I was hopi g it would be available online somewhere. Thanks
(quoted from post at 21:37:18 04/23/17)
Dean
You will want that manual, even if you find a used copy somewhere.
I have one and I would be willing to scan and email that section.
Shoot me an email via YT so I don't forget to go out to the shop
and get it. I'll have to bring it in the house to scan it.
Thanks, I would appreciate that, I am going to continue looking for a copy of the manual. I am not sure how to send an email through YT so if
you could drop me a note on how to do that I will send you an email address to send the scan to. Thanks again I really appreciate it.
(quoted from post at 18:51:47 04/23/17)
Dean
