Acaswell, located in SW Utah. Dean-Sean & Ultradog, you guys are right as usual. To switch one of these Tractors from standard to SOS
involves different rear axle plus removal of clutch , I think different bell housing. Hardly worth the effort. Cooling lines are optional, trans are
plumbed for the connection. I would think it would depend on how hard you planned to work the tractor. I certainly was not planning on that
kind of change. If someone out there has a 2-3000 SOS that has a bad trans. These are available to bolt right in. WAY cheaper than repairing.
