Hello, I have a 1958 FORD 641 with the Howard low range unit. I bought it at auction 8 or so years back, kind of a package deal as it was thrown in with a Kubota tractor which was what I was after at the time. I ended up selling the Kubota,which gave me the FORD for really less then free, and t I still have it.
Anyways it came from a closed Japanese Nursery started before the WW2 era in Richmond CA, the owner in his late 90s, had died a while back and everything was finally auctioned off by his relatives. It was kinda weird, as this rather large, old run down nursery was right in the middle of one of the worst crime ridden areas on the planet. The tractor, when I got it was right in the middle of a tuneup, the hood was off, it had new oil,filter, belts,plugs,wires, points etc but the guy couldn't figure out how to do the points so he gave up I guess.(funny because I never tried either as I changed over to Pertronix Elec. Ign. system the very first thing) It originally had a loader attachment as well. I sold that off right away as I had no use for it, as I have much better options for that type of work. I am now restoring the FORD, just put in a clutch.
All I have ever used it for in the last 8 yrs, was close in tilling around the yard, once a year. It only has 2200 hrs on the proof meter.I think its original hrs.
I do have to say without the Howard engaged I can't see how this tractor would work at all for what I use it for as the first gear is so not low enough for me. Come to think of it I never shift it out of low range, and just use the 4 gears that way.
My 1st question is what was this Howard unit originally marketed for? I read it was for rototilling but I doubt this in my case, as this tractor doesnt have a PTO! I learned that the hard way when I removed the rear PTO cover and had oil all over the place! That was an unwelcome surprise.
I'm thinking the original owner or dealer must have thought the tractor didn't have a low enough first gear for close in loader work?
And regarding the lack of PTO, is it normal to have the shift lever but still not the PTO option? And can I just buy the PTO shafts I see for sale to gain this option?
One more question, on the three point hitch system, with the engine cam driven pump, is there any filter for this? I can't seem to find anything that protects it or needs to be changed, I thought that was somewhat strange as even the power steering pump has a little filter inside it. Maybe Im used to modern equipment as that all seems to have hydraulic filter(s.)But now come to think of it none of my older crawlers with the rear PTO drive BEE GEE pump/systems don't have filters either. Thanks Nick
