78 Ford 3600 diesel wiring diagram?
BobReeves
Next issue on my 3600, going to replace the instrument cluster with an after market and could use a good wiring diagram. Have the IT manual on order but a few searches on the net found posts from others saying the diagram in the IT book isn't that great.
Anyone have a good diagram for a 1978 3600 diesel the could share?
Very simple switch, all you need is a test light.The illumination lights will turn on with the headlight switch. Install them first. 12 Volt supply will turn on with the key, Ground. Temp sender and oil pressure is the same color as where it hooks to senders, Fuel gauge sender is very easy to locate and you may or may not have an air cleaner restriction light.Tachometer cable is a no-brainer.
Did that, nothing usable. best was a few JPG images someone had scanned and posted several years ago but they were pretty much unreadable. Found all kinds of diagrams for older Fords but nothing usable for the 3600.
