85burbanator
It's never ending haha. Finally worked my way around this thing and got it running great. Now the starter doesn't always engage, it spins and sounds like it hits the fly wheel but takes 20 plus tries before it engages and turns the engine over. I pulled it and the teeth on the starter gear look good, as to the teeth on the flywheel minus some slight galling from the starter gear where it must not be lining up.
Doesn't appear to be adjustable outside of a shim or so. It's never had this issue until now. Maybe 300 starts since I've had it.
Side note, high range on this thing is stupid, 6x4 trans and crumby drum brakes brings the pucker factor to 11 haha
