Hi all and thank you for stopping in.
I've searched here and I think I have an idea what my problem is but I wanted to ask a quick question to help me cement things.
My 3600 has no power. it puts out a little smoke that is blackish and greyish and it seems to have more power when first started but that might also be because I haven't started in gear yet.
I suspect its not getting enough fuel but here's my question: if it acts doggedly but then if I shoot a quick shot of starting fluid into the air it immediately growls to life.
(I know I should not do that so save the speeches on that)
but anyways does that mean the compression is fine and that it is likely a lack of fuel or can the compression still be bad?
* I also read about timing / couple other things which could also be the problem but I feel its likely one of the two choices I mentioned.
further info would be that it seems to idle okay its only as the gas is increased that it seems to struggle. I have checked the air filter, seem to be getting enough fuel at least when I pull the line up by the injectors.
There is one last thing I am going out now to fool with that being the return line for the fuel. I read where that could be a cause for problem in this area.
thanks again. I figured if you could tell me whether its the compression or not; that I would at least know whether I have to go buy another tractor or not because I don't know enough to even consider tackling a compression problem.
