Ford 800 fuel tank aftermarket rear bracket
I purchased a aftermarket tank used and rear bracket that bolts to corners of tank and then to tractor missing somebody have one .thanks tom
I have one off a Jubilee tank. They are different sized
tanks, but I'm not sure the brackets are any different.
Maybe someone can tell us for sure.
It has only one hole in center of tank for drain cock the bolt kind .there is no sending unit hole .maybe someone
will know if the two diffrent tanks use same bracket .
fuel tank is 16 1/2 by 28''. Rear hole for bracket to
mount to tank are 15 1/4. Do you have a air breather tube
for a 134 cubic inch ? Its not the 90 degree.
Was just looking around for that air breather tube.
Don't think I have one of those other than N series.
