Kevfulltilt
New User
I purchased a new power steering control valve for my 1963 Ford 4000 Industrial. Still trying to get power steering working from my last post I have made with no luck. Still power one way and hard to steer the other. Steers fine if I disconnect cylinders in both directions. This new power steering control valve looks identical to the original one until I took it apart. There are no special plungers or 1/4 balls. All holes have 2 plungers and a spring in the middle. Wonder if this is a upgrade or did I get a bad part. Also when I put this on the tractor do I tighten nut till washer is flat then back off 1/6 turn? Manual says till all endplay is gone. I am attaching a pic of new valve.[/img]
