Kevfulltilt
New User
A couple of weeks ago I posted about a problem I had with power steering on a 63 Ford 4000. This tractor will steer with power to left and hard to steer right (no power). I have replace both cylinders (one for each side), all lines and finally the $600 control valve. Still same problem. I have turned the control valve upside down and it will have power to right but no power to left. After turning control valve back to right way I am assuming I am not putting the control valve on right. Should I tighten nut until it bearing races reaches spool on control valve then back off 1/6 turn or tighten till it hits the plungers then off 1/6 turn. Also need to know where steering shaft needs to be. I have been tightening to plungers then back off 1/6 but when I di that I have to turn steering shaft counterclockwise in order to get threads. I am thinking now I should be going to the spool then off 1/6 but I don't want to get it too tight. Any help appreciated.
