Ford 4400 gas flywheel fit Ford 2000 gas engine?
markct
So I bought a tractor today that was in two pieces, apparently was split to do a clutch, flywheel is off and missing. So basically have a complete tractor minus clutch and flywheel. I have a flywheel from a Ford 4400 engine, will that fit? Both are gas engines. I bought it as parts but the thought of making it a working tractor is floating around the back of my mind a little
It should bolt on the crank. But you will need to match the clutch that was in the 4400 and that may not work for the 2000's transmission. If the 2000 has live PTO, you are probably dead in the water. If not, some creativity with discs and pressure plates may be in order.
It's not live pto, and at first glance looks like it is the same input shaft, I haven't measured it to confirm tho. I really should just park it outback as parts and sell the Ford snowplow off it, I don't need anymore projects or working tractors,but the idea is somewhat tempting
O.D. of the PP ( bolt pattern) will be different I'll bet. That's where the creativity comes in. 4400 has IPTO does it not?
4400 it came from had no pto, I suppose it's workable as I have the pressure plate from the 4400.
