Attachment pin for lower three point arm
matthies
Are these common to come loose. Was planning on pulling complete axle housing off to repair and just tighten up the pin, maybe replace the pin once I see which is worn the worst. The pin is $65 from Ford. thanks chris
yup, they come loose. IMHO.. having a threaded nut on a pin that is just friction held is asking for trouble. ford should have went with a lynch pin setup like many do now.
