jubilee pto seal
matthies
So can I just remove the 4 bolt housing leaving the shaft in the tractor? I have the oil drained already to change it out. thanks chris
As stated.. 4 bolts and the whole ordeal comes out.. then you can remove the bearing carrier and pop the seal out/in.
PS.. you need to drain diffy AND hyds oil sumps.
Had them drained already to service, laying by it last night noticed the left pin/bolt for the lower three point arm is leaking from the axle housing, so guess that's coming off next. chris
