68ford5000
New User
I recently purchased some parts off this website for my Ford 5000. A tach drive, a tach drive cable, a dual fuel filter set up, and a fuel shut off. Of all of these parts, I was able to use exactly zero on my tractor. The fuel filter "bolt on" unit had the pipe fittings tapped so deep, I bottomed out before sealing and it leaked fuel like a sieve. Next on to the tach drive unit (also a "bolt on"), the square drive of the unit was so much larger than the square cable they sent, or even my original Ford, that is just slipped passed instead of engaging. Complete junk. Then on to the fuel shut off. Works great when closed, but when open, leaks like a sieve as well. Four hours of fooling around draining fuel, bleeding fuel system wasted. Anyone else have any experience with the quality of these after market absolutely worthless parts?
