My 1977 2600 lost the lift suddenly. I had my log splitter attached and it was lifting fine. it has plenty of hydraulic power to run the splitter but no lift action at all. Won't even offer with nothing on it. Fluid is full and as I said plenty of pressure.
I pulled the hydraulic cover since many suggested unloader valve stuck. Pulled unloader valve plug and everything was fine and free. Bought all new o-rings from Messicks and reassembled. I tried air checking and all it does is blow air back out the return port no matter what position you move the levers to. Piston is bottomed in cylinder and doesn't offer to move. The control valve in the cylinder housing is free. All linkage is fine, picture attached. Where do I go from here?
I'll have to work on the picture. If i try and post in the text it stops because of content and if I try in the Image URL it says I'm liniking an album. I'm using Photobucket.
